23cc KM Baja 8000rpm clutch spring
turbohvn
Does anyone know if the newest batch of KM 23cc buggies come with the red 8000RPM clutch spring installed? If nowt installed, is there any reason not to install one?
I have the 23cc km baja and i don't think it has 8k spring as i have one in my fg marder and that seems to rev higher before the clutch engages,but am going to install one as the carb seems to make my baja a bit boggy at low end( i have just put a walbro 603a on and will test tommorrow.) I don't see the problem with fitting the 8k clutch/spring,
There is also 9500k available. That's what I have, it helps with the taller gears along with my 28.5cc big bore kit.
