23cc with 2mm stuffed stroker crank
nvm I just tried it with 2 stock gasket's and the piston hit's the crank so it will not work.
the 23cc piston is to small to clear the crank on the down stroke it hits the crank on the down stroke.
Bigger CC engine with +2mm crank have a different shape under the skirt to clear the crank on the down stroke.
But don't know if it's possible with the 23cc since it's smaller, on the intake it's doable since you can play with the duration a little, but on the exhaust side, you don't want to open the port at TDC.
