24mm hubs
Boriqua935
Will the 24mm axle/hubs of a 5b fit on rampage mt? Which do I get? Do I get 4 5b rear hubs because rampage is 4x4? Has anyone done this mod?
I just did this on my Dunerunner. i purchased 4 rear 5b hubs, works like a charm. very simple change, just use a drift pin to push out the old pins. The hubs slide off and you reverse the process to reinstall. Some owners are using shrinkwrap, or silicone hose to insure the pins stay in place, i used a drop of CA glue.
Yep 4 rear hpi hubs and you get rid of the 23mm hub so you can run baja rims!!
When I had a TT, I bought the Vertigo axle extenders some time after I had my HPI hubs. Honestly I wish I didn't get the HPI hubs and just spent the money on the Vertigo extenders.
Dang James extenders on an already way wide buggy?? LOL:confused:
yup same here..
