Ron E
we'll see soon...Martin said:For a rampage or a 4wd I will definatly choose a 36mm 28mm stroke, and probably bigger for an all aluminum rock with MT tire, however we are limited to 30.5cc for now.
For a 2wd feather Baja, this is another story since you loose a lot of traction, less moving parts.... etc.. your always in high RPM, where a small engine enjoys working.
It'll be interesting to see the Ron E's (I think) 35cc, I'm curious to know how much RPM that engine can make....
diff cups at moo's being modded
steel layshafts ordered - rampagehopups.com
mcd dogbones ordered - largescalerc.com
steel gears here
should make good power and torque... this vehicle is not for racing, it's for shredding around on hills and long smooth jumps and just having fun with a BIG motor. I bet it will pull a car -
it's not about needing a big bore kit, it's about a 40lb 4x4 5th scale badass buggy with tons of torque for fun. it's all a matter of opinion and personal taste and running conditions and what YOU want. some may not need the fastest or most peak hp or the most rpm's... a screaming small block or a torque monster big block, it's all good.
