2wd...??.. and drive pin replacements
Ictinike
Hey Guys, I lost a drive pin today and did not feel like waiting for the new ones to get it, so I removed both front CVD's and the dogbone from the center diff...
I am can not see any harm coming of this..but thought I would ask
also, does anyone know the diametor of the stock drive pins.... could I go buy some grade 8 "M6"(or what ever size) bolts, cut the head and threaded part off...and use them? anyone tried? should work..cost $.30 and be stronger than stock
i seen a video of a guy with rear-wheel drive rampage and it seemed incredably smooth driving and turning i believe theirs only one way to fix or replace it if you don't have the right part is use a hardened steel drill bit the same size diameter as the original drive pin.
