Pollishman
What are the Carb settings for the 30.5?
IF I remember it's H=1-1/4 L=1-3/8 turns from closed, and the idle screw set at 1mm open
i just go 1-1/4 accross the board and adjust from there,but thats what works for me
standard zenoah carb settings,
could be just that the clone carb is not machined with the tolerances of the walbro,
those are basic starting point settings,it's up to the user to be able to determine how much to adjust,if these settings made your carb flood you should of leaned it up and been able to set the starting point of the carb for referrence.
6) CARBURETOR ADJUSTMENTThe carburetor comes with a standard setting, it is for
optimum performance under the barometric pressure and
climatic conditions at factory, so it may be re-adjusted
according to load applied.Idle rpm : 4000 ± 300 rpm (STD Spring)L needle : 1 1/4 ± 1/4
H needle : 1 1/8 ± 1/4
http://www.zenoah.net/ddoc/ZENO/ZENO2012_AAen/ZENO2012_AAen_G240RC,G270RC,G290RC_.pdf
http://www.zenoah.net/ddoc/ZENO/ZENO2009_AAen/ZENO2009_AAen_G230RC,G260RC_.pdf
