30DN dtt-7s v2 fuel issue
Rcnut24
New truck won't start or run if the fuel cap is tight enough to not leak. If you loosen the cap enough to run the cap leaks fuel....normal to run is roughly a1/4 turn after the rubber seats against the tank but then it leaks.
found out the carb adjustments were NOT for the 38cc out of the box. opened them up and came to life....
