PISTOL PETE
MY STOCK SERVOS LASTED A WHOPPING 3 FEET.
SERIOUSLY. 3 FEET! I HAD THE D/R TURNED WAY DOWN TOO SO THEY WERENT EVEN AT FULL EXTENT. ANYWAY I ORDERED TWO 5745s DO I NEED BOTH? ITS IN A MT PRO V3
Will I Have To Mod My Holders For Them?hamster Huey said:i Take That Back. One Is Working Fine For Me. My Problem Was The Servo Saver Nut Backed Off Making The Steering Soft. It Alive And Strong. Im Gonna Continue To Use Just One.
No. I haven't had a problem with the rounded sides.PISTOL PETE said:What About The Rounded Sides Do They Need To Be Widened At All For The Square Servo?
i cut the servos. and put a bigger washer so it catches the case a little. its been working out good so far. thankshamster huey said:You can cut the tabs on the servo case instead of modifying the mount. Either way works. Servo mounts are cheap at Ramphopups, largerc, and daves. Servo cases are cheap at servo city. So don't be afriad.
