8 shocks
yea its a lil diff cuz i wanted to screw it into the thicker part ot the arm. im going to try it both ways.
You may have to find a lighter spring rate now that youre running 2 springs at each corner, but i bet the dampening is much better. I don't know if you can do it on these shocks but that would be a perfect setup for running one shock with a bound setting and the other one on a rebound setting.
bashed the heck out of my mt and no bent stock shock shafts!! so now i have to find a way to do the front.
Is there any way to get ahold of part numbers 050001N, 050002N, 050012N, 050013N ? They are Alum upper and lower susp arms that allow the use of two shocks per wheel.
They are listed in the back of my manual, but I can't find them anywhere...not even in the pdf manual posted in the Gen. Disc. forum here. Has anyone seen these?
I'd love to run 8 shocks, and I'm sure I could make them work with the stock arms, but I'd rather have ones made for the purpose... I've got the Pro, so all the susp. is Alum, not worried about how to mount or weakening the arms with holes drilled in 'em. Just worried about clearances and rubbing.
Thanks for any info!
Parker
Rob said he and darin were going to get a bunch of new parts a while ago which included the double shock arms but nothing ever came of it.
Parker
I made Double Shock Mounts Arm p#050002n
http://www.redcatrampageforum.com/showthread.php?t=3410&page=2
