Trickle007
Contributor
Just purchased an 813 carb. Is there anything special I need to do to install or is just a straight up take the 2 bolts out apply new gaskets and lok tite the bolts back in?
that should do it, starting procedure varies do to no choke, I read a nice thread on it somewhere... but basicaly it was prime the bulb, blip the throttle 0nce or twice and fire it up... mine always starts nice like this and throttle repsonse in awesome.Trickle007 said:Just purchased an 813 carb. Is there anything special I need to do to install or is just a straight up take the 2 bolts out apply new gaskets and lok tite the bolts back in?
Thanks, Didn't know that...max 1 said:PLUG THE HOLE in the back side exsposing the thotlle shaft to prevent vacum leak and dirt from entering motor.
Cat i have the 813 carb and i have the same problem takes like 5-10 pumps to get gas even in the bulb, im thinking a carb kit or maybe a new carbs (wt-990) in order.I think I have a problem with my 813 accelerator pump. Dam thing takes like 20 pumps for it to startup.
I think ive got 2 or 3 813s in my basement all of them have the wobbly throttle shaft. Im going to stick with a 668 from now on.DemonRC said:Ya my idle is always erratic too. I think a rebuild is in order cause I think I got a leak somewhere. I don't trust the dam thing cause the throttle shaft wiggles around like crazy. They need to stick in a brass bushing with an oring where the shaft enters the body. Every used 813 I've ever seen has a wobbly throttle shaft after a few months.
