8K RPM clutch kit
Corso
I am going to install this clutch on my Redcat Rampage MT v3.
Looks to be a pretty straight forward install. Are there any surprises that I should be prepared for?
Thanks.
Higher engagement rpm, the higher engagement rpm could be harder on the running gear on pavement. its best to be on the throttle hard so the clutch is not partially engaged and slipping. The heat you see?
Can I use the stock clutch shoes with 8,000 RPM spring? Or do I need to get the High performance clutch shoes?
The entire kit is so cheap I opted to buy it over just the spring, and now I have my stock clutch as a spare.
