flarcer
- Florida...70 degree winters
I've got a Zenoah 23, no fancy porting or anything, that I've been running on 93 octane for 2 tanks. I now have access to 96 octane, will this be OK to run?
Mix high-octane (over 95) gasoline and high grade 2 cycle oil (JASO FC Grade oil or ISO EGC grade) in the ratio of 25 : 1.
I have a solution to detecting predetonation... all you need is some Acoustic Emission monitoring kit from Holroyd instruments, it only costs £2k for the basic set up.
I have the kit at work which I use to diagnose bearing problems, it should pick up the double flamefront in the combustion chamber too. I'll give it a go later this week
Remember that mixing oil with the gas (like on a two stroke) lowers the octane rating of the fuel significantly, so even though they may be lower compression than a four stroke, they often require around the same octane of fuel.
You need the oil to provide the compression in a 2 stroke(It provides the seals around th piston rings as well as lubricates the engine) The amount of oil you run will be the determing factor on this. The more oil you run the higher the compression to a maximum that the engine is capable of. That is why you see usually two values on compression for a two stroke, it is harder to create that seal at high rpm's therefore the comprssion goes down. If you run too much oil then you decrease your octane level so greatly that you then limit the power making capability(potential energy in the fuel) of the gasoline, so there is a bit of a balance there. If you run oil rich mix say 25:1 to 30:1 then I would run 93 octane. If you were running somewhere around say 35:1 to 40:1 I would try to run 91 octane. It is always good practice to start with the manuals reccomendations, but it has no gaurantee that it is going to be the best setup for you, you may have different air density, fuel quality, oil quality than they do in giving you those numbers. A little trial and error will set you in the right direction, part of the fun in dirtbikes is finding the best setup so you can beat the next guy with the same bike...lol:banana:
i've just been having a google, and found the following tidbits.
http://www.thumpertalk.com/forum/archive/index.php/t-749087.html
Seems to make sense that the 2 stroke oil may reduce the octane number, so you may need higher octane to compensate. Our engines definately fall into the high RPM catagory so need a stronger oil mix than bigger 2 strokes.
Starting to wish I'd paid more attention in class and taken the IC engines module....
