A few mods to the front end you might fined helpful
The 3mm screws in the steering plate and inner turnbuckle can come loose and fall out
Here are 4mm countersunk screws with cup washers and some nylon tube cut to 5mm long
4mm nylock nuts, don't think these will come loose anymore
Next the inner turnbuckles, I'm using MCD stand off ball's
They are exactly the same size but with a 4mm hole
Just need to drill out the steering plate 4mm
All fitted and no more problems with loose screws
Another quick fix is for the lower Hub screw, I lost one after it came loose and I know others have had the same problem.
Simple to solve, drill a 2.5mm hole in the slot of the hub carrier and fit a 3mm screw
Now the hub screws are held in place
