Silent_Chaos
25:1 means that every 250ml of fuel, you need 10 ml of oil and mix them (synthetic is better). So 1liter of fuel is to be mixed with 40 ml of oil.
There are a lot of vids on youtube that teach you how to break an engine.
The redcat will be alive after almost 5 full tanks.
Breaking is done by 1st adjusting the low needle of your carb to 1.6 turns(open it) and letting your engine run without driving it. Keep the high needle at 1.75 turns. Just start it and leave it till ur 1st tank is finished. The point is leaving ur engine running in low rpms.
After the 1st tank, adjust your low needle to 1.4 or 1.5 turns. And the high needle to 1.5 turns.
The goal in the 2nd tank is to make your car run half a throttle at a time. Half throttle for 3 secs and stop. Half throttle for 3 secs and stop... etc..
Keep repeating the above till your 2nd tank is done.
Congrats. Your engine is broken. You can now drive full throttle but don't push it.
Now, Lower the low needle turn to 1.25 and keep high needle to 1.5.
After your 5th tank. Drop the low needle to 1 turn. Keep your high needle at 1.5
Good luck, have fun and bash hard
