Adjust the rear and front traction?
waqr
Sweden
Hi!
I`m about to purchase a Rampage/Maverick MT very soon. I have mainly driven 2wd trucks before and I really like to have my cars a bit oversteered and to be able to do wheelies on demand :) Since there is only a diff in the front and in the rear on the Rampage/Maverick MT, is it possible to get a more oversteered car by putting thicker oil in the rear differential or how do you adjust this?
It's a lot harder without a center diff. Heavier in the back will lessen rear traction, which can cause an oversteer effect. Making the back want to slide out a bit, and the front running thin for the tightest turning without 'pushing'out of the turn is your best bet.
I ran 3K front, 10K rear for a while.
Front
Thinner :
increases steering into corners (off-power)
if oil is too thin the steering may become inconsistent, especially it can lose forward traction (and steering) during acceleration out of corners
Thicker:
increases stability into corners during braking
increases steering on-power at corner exit
Rear
Thinner:
increases cornering traction
Thicker:
decreases rear traction while cornering
reduces wheelspin
You won't get wheelies on demand with a 4wd especially the way our motors are setup. If you want a 4wd and wheelies I'd suggest a FG 4x4 with a good engine and Dominator torque pipe (not the high speed Dom). This is the only 4x4 I've ever wheelied on demand and it took a TS reed motor and a Dom torque pipe to do it. You won't like the way the car understeers on power in the corner though. Dam thing pushes like crazy.
Hi!
I don`t plan to use the original engine that long. Firstly I will add a decent carb and a Dominator pipe and after that I will probably install a ported Zenoah 30,5 for more power. I understand that it might be hard to get the Rampage MT to wheelie but it sure would be nice to try :)
I have already had the FG so I thought I would try a bigger truck this time :)
