Pollishman
Just curious what you guys use to clean your trucks with. Is there cleaner that works good and doesn't ruin the plastics?
if its real dirty i use an all purpose spray cleaner then air compressor to blow it off. then i finish it with (or if its only dusty this is the only step) no touch tire foam. spray the no touch let it sit till the foam is a liquid then blow off with compressed air.
Since installing the Proline Undertray cleaning has become alot easier as it keeps the crud out of the chassis. After a run I blow the car off real good with an air compressor and that seems to be good. haven't really gotten into any thick muck that needs further cleaning with chemicals or water.
