Aftermarket Air Filters
Chief409
Rosamond, CA
With the stock air filter, it interfered with the linkages to the throttle and brake. With a DT1 filter I gained two things, no more interference with the servo linkage, and MUCH better filtration.
Hey chief if u get a small 1" round by3" long spring put it inside the filter this will help the filter from collapsing on itself...provides better air flow...
yea, it gives the filter more dead air space. you can also get a clear 35mm film container and cut one end out- drill a bunch of holes- remove ALL the little plastic flashing burrs and round off the edges- I have the 2 and 3 stage filters.- I use the 2 stage 90% of the time- more dead air space.
Here I'm running in talcum powder, or sand when we go to the beach so I have the 3 layer DT1. Love these things, the only filters I've seen that match dirt bike filters.
I was planning to mount the GPS on the DR today and post another YouTube video, but I'm down with the flu.
Im using a baja filter. All i did was switch the throttle and brake linkage around so they make a X. Trimmed the ear on the servo and made a new hole for brake linkage. This is with a 1 inch mani and 990a carb...
Chief409 said:
Here I'm running in talcum powder, or sand when we go to the beach so I have the 3 layer DT1. Love these things, the only filters I've seen that match dirt bike filters.I was planning to mount the GPS on the DR today and post another YouTube video, but I'm down with the flu.
Yep, it gets dry up here too, sometimes so bad that I change the filters after one tank of gas- do it in under 60 seconds- I keep a assortment of these dt-1 filters in a large zip-lok- oiled and ready.
