Air Filter Upgrade Suggestions
  • Thread starter Thread starter DustyR3825
  • Start date Start date
D
DustyR3825
Guest
Ok, So let's here some suggestions on Air Filters. I have already installed a JetPro SidePipe and now want to get some better Air Flow. I was also thinking of cutting out the clear part in the body (windshield I guess LOL) which is in my opinion restricting Air from flowing through the filter and also keeping the engine cooler. Does anyone see any problems with that idea either?
Do you have the HPI part number for this upgrade and is there any modification required?
MT air filter
Deluge said:
Here you go.
Link
Deluge, Rob, Will this air filter work on my MT V3? My rollcage has a bar running across the filter. Do I need to remove it or the air filter is short enough that it won't hit this bar? Thanks
you should buy the phatdad angled shreadstack and you'll clear it all
The shreadstack keeps the filter above the servo linkages. It is not a good choice for the XB as it won't fit under the body.
I did. It's huge! It is bigger than the pic looks. Larger diameter than the HPI filter with the prefilter installed. So no it's sits in the drawer waiting for the 5ive build. I'm one part on my way. :D
Did it hit the body? I'd assume the only issue would be the throttle linkage. If that's the case you could probably use a one sided servo horn, and if necessary, bend your own linkage. Now I need an XB!
