Air filter
RampageHopUps said:
I just notice in the picture, putting the linkage on the bottom of the arm may be perfect. I'll have to check if it clears the rod.
So Rob you encountered the same thing?
let me know when you put the linkage on the bottom of the arm and let me know.
Cheers,
John:)
OK, I mounted the servo swivel upside down and it works perfect. Now clears my Baja aircleaner. Now I can run a TGN billet front piece, custom engraved!!!! Woohoo.
That looks much better. I even thought it was close on the stock air filter.
I have thought about reversing the sides then reversing the servo direction on the radio. will probably take a spacer on the carb to get a direct line , I think it would make the carb linkage more "Happy" though.
