I recently purchased a King Motor Baja KSRC-002 with a 30.5cc engine and have been fighting an air/fuel problem after 2 tanks of fuel. I went to start the engine one afternoon and could not get it to stay running without holding the throttle open. I went to the internet and read several different forums that instructed me to open the LOW side needle 1 1/2 turns from closed and the HI side needle 1 1/3 turns from closed. Making small adjustments (1/16 turns) to the LOW side while trying to start the engine I found that I could not get the engine to idle unless the LOW side jet is completely closed. (Hmmm!) As soon as I crack the jet open just a small amount (once again 1/16) the engine stalls. With the LOW side jet closed I sprayed WD-40 around the intake manifold area to check for un-metered air getting into the engine. (No changes in the idle were detected) I replaced the spark plug. I removed the carburetor, disassembled it and thoroughly cleaned it with carb cleaner and shop air. Once carb was cleaned and reinstalled on the engine I was still having the same problem. I have inspected the plug and it has good color.(light charcoal gray...not black and not white) All in all the car runs great and idles as long as I keep the LOW jet completely closed but I am worried that running it like this will cause a more serious problem. If anyone has experienced this problem please let me know what to do. Thanks
