Negative, all you doing is slowing the air velocity, untill you get to the v stack. The engine will only take in what the carb can flow at a given throttle position. The "big tube" idea is great for wot, the smaller tube that more closely matched the carb will yield higher velocity air that will help improve torque. At any rate you have 2 limiting factors for how much air can get in the engine, carb size and airfilter capacity.(I'm not talking about pumping losses, or how efficient the air can get to the crankcase post carb) Most of us run rather large air filters so that doesn't typically seem to be the limiting factor, so all you have left is the carb itself. Now I will grant that the tr box has 2 90* bends, and that's never good for airflow, but from a volume of air standpoint, they should work equally well for doing the job asked of them. Both are more then capable of out flowing the engines needs.
