Air leak
Rsaint
Ny
Hey guys I'm back again. Can u guys teach me how to check for air leak. Just changed my carb to 813, new air filter, and new clutch. Non vented tank. Please help!: :confused:
Update.. My 8000 rpm clutch I installed backwards. Vent the tank next: is there a quick fix for now until I get my dubro inlet? Notice every time I tilt the kit fuel seeps out of the grommet where the fuel lines are not the cap. Is that normal? Thanks
For a temporary vent fix, take the cap off and remove everything except the rubber bulb, then enlarge the vent hole on the cap a little. If you flip, the gas cap will leak since there's no check valve on it, just letting you know. Make sure the grommet it seated properly, but honestly, mine has always seeped a little. So if it's not a huge leak, I wouldn't worry about it.
Very eventful day. My kit finally tuned. Almost can keep up with an fg, xb,5t. 4wd awesome but being that we were bashing on road my tires look worn out. Now have to look into slicks plus will try 2wd maybe I can really at least side to side. Hoping. Still no break. But in time I'll get the problem resolved. I loved it off road but lots of things to clean plus doesn't pay especially if fuel leaking my the grommet. Same issues with the other guy and he told me better off buying a new one. Loud as hell!! Has ss pipe.
