Sorry- I ment to say James 1996--- Its still early here-darkalfred e numan said:After I bought the mighty XB I pulled the engine and cut pieces of plastic window screen for the air intake holes on the engine block- I used automotive Goop to hold- same for the recoil start cover-- This will not work for sand dunes- anywhere else it works fine- Yea, theres no bling on this XB- its all about function- not form!!! Do not try to use the Goop to build a foam filter- it will eat the foam and cause a engine failure- Say GTS 666- In AU there is a shop called Power slide racing- In the engine section they sell Viton engine seals- kinda spendy but Viton is more durable than rubber, the ad says An AU company called Outlaw-rc - either makes these or buys them then puts there name on them- Never found these anywhere else but in your country- Viton is what the needle tip on the Walbro carbs is made of- though stuff-------
