atom3624
There don't seem to be many options on gas caps for FG trucks, but plenty for Baja 5B / SS.
Do the Baja caps fit the FG?
Thanks.
Thanks.
OK. I understand that bit. Even the old, 'safest petrol tank is a full one'.
Is it likely that I will need to reset the carburettor once the vent tube is fitted?
I also understan the 'obvious' that the tube outlet should be above the level of the fuel to avoid syphoning ... !!
I see that the FG one does have small vent holes anyway.
I've removed the seal on the CNR cap, and will use the FG insert, and clamp this onto the tank with the CNR cap, plus have used the tubing, obviously away from the exhaust, using Duct tape to hold it firmly to the roll cage.
I think this covers most items you mentioned.
Thanks anyway.
hi guys
iv got a rsx racing brand alloy fuel cap with fg insert fitted on my fg mt.
and with it screwed on straight and tight when full,the bloody thing leaks.
do you guys find this happens with all alloy caps ??
thanks
glen
BtB, what are the wheels you've got on the truck, they look stunning?
Are they alloy?
Is the offset the same as stock - or even more?
What are the tyres?
What diameter are they? Same?
Mounting?
