^ ThisWhy not use the Smart packs? Cost?
It’s nice that they auto discharge.
Because when you have numerous packs/types keeping on top of them all along with my other SLAs and other types becomes a headache, i know how to care for batterys, having this feature for me is priceless, one less thing to manage, auto storage mode is a great feature, all lipo packs should have this as standard imo.There is zero reason to have a self discarging lipo. It's just another expensive gimmic so people don't take proper care of their batteries. Besides that any quality charger won't let you over discharge a lipo if you set it right. Learn how to properly care for your batteries.
for others it maybe an issue, just because it works for you & easy to manage, don't mean the same for others. Like i say, i think its a great feature & i see no reason why other manufacturers don't do the same with all lipos, all this balance charging/voltages/discharge/storage mode etc is yesteryear! ..i just plug it my lipo, no matter what type/voltage my lipo's are, and thats it..my charger does the rest with no need to change any settings or do a discharge afterwards, unless you want to manually override it for whatever reasonI was into scale flight with helps from sub micro to 450 size, multiple 1/8 scale e words and a few scale crawlers. Not to mention keeping after all the batteries for my flashlights. I haven't ever found it a hassle to keep up after them. I see zero need for a self discharging lipo.
i disagree on that! hehe yeh, each to there own etcWe're just going to have to agree to disagree.
Make sure your scissors are sharp and oiled before you start mowing your grass. Maintenence is a key part of using everything. It's not automation, it's a battery management system built in. It uses power to manage the batteries state of charge, from the pack itself. There is nothing to stop it for slowly discharging till the battery is flat dead. The whole principal banks on the user regularly using the pack and peak charging it. Let it go as long as a std pack and you'll be getting into low voltage territory. It's pure laziness. I have dozens of lithium batteries to keep after. It take a few minuets to run around and check voltages every few months.Why even respond with this nonsense? I could cut my lawn with scissors, but why would I when technology makes my life a little bit easier?
Some of us would rather not waste time worrying about discharging batteries if we don’t have to; I am glad advances in automation and technology exist!
It's absolutely nothing like carburetor to fuel injection. There was little to no worry that you're battery would over discharge or your engine wouldn't run with the advent of fuel injection. (I'm just going to assume you mean electronic fuel injection, because mechanical injection was around for a long time before that.) There was also no need to worry that if your battery went dead you would have any other issues then a dead battery. There is real cause for concern with a severely discharged lithium battery. All you've done with this set up is add a failure mode that the battery doesn't need.
No we will never agree about this.
It has everything to do with the conversation, that's what the premise of the issue is. The battery includes a device to drain the battery to storage voltage. Ie it can over discharge the battery. That just so happens to be a potential issue that no one should have to worry about. The entire system is based on you using that battery every so often so the monitoring system doesn't parasitically lower the voltage too much. It's a stupid system with zero up side.
he and I will never agree on this subject.so this is going back and forth and not going anywhere...
The real question is what oil do you mix with your batteries? and what ratio? I like a 10:1 grapeseed....
