DemonRC1
I rearranged my linkages a few weeks back and figured I share my setup since it's been working great. I installed both linkages on the same side of the horn. All you have to do on the brakes is move the linkage to the outside of the brake shaft so that it pulls to engage the brake. DO NOT keep the linkage on the inside of the shaft because the cam will engage the inside of the brake pad and the sharp edges of the pad (on the inside) will gouge your discs. Also, the Rampage has always has really strong braking. It doesn't take a high end servo to slam on the brakes. I ended up epoxying 3 brake discs together as a single brake disc and removing one of the brake pads. The braking is much smoother now and still has enough grab to lock if you want it to.
