Aluminum sleeve for Diff joint cup and Center joint cup
MTMIKE
New Haven, In
Has anyone tried using an aluminum sleeve over the diff joint cup, center dog bone joint cup or axle CV joints on Rampage MT? I notice the pins get really loose inside and slide one way or the other on the dog bones. Was wondering if a small thin aluminum sleeve and some silicone or even heat shrink to help hold everything together, is worth a try? After mild bashing that is one area I always seem to have to redo. Lock tight on the set screws does not help all that much to hold them together.
Ildy666 said:
I use copper type l pipe fits perfect.there's a thread on it under drive line
You have any pictures or part number of the pipe you are using? Here are several picture of what I was thinking.parts and sleeve.webp
/monthly_2014_05/583c60709d13d_partsandsleeve.jpg.14be6db7230b09bac6ef7532f2189fdc.jpg
/monthly_2014_05/583c6070a091c_CVjoint.jpg.95fa980b08e810a8486dd089c2be17f5.jpg
I believe 7075RC makes sleeves. You could also grind down the middle of the pin a bit so the set screw can lock onto it.
Like this.
media.nl
Yep that's how I did mine.go to home depot go into plumbing aisle find 3/4" type " L" copper pipe and that's it.bring a diff cup to match it...
