AMS hydraulic brakes
Timetoshine
Someone got a video on how to put oil and bleed these brakes ?
Or manual installation ?
Do you guys know where I put oil ? Big hole for oil and small one to bleed ?IMG_4939.webp
not the same brakes but i have some GTB ones and the easiest way wirh those is to reverse bleed em fella (y),
syringe and a bit of fuel line attach to the nipple on the caliper and push fluid in from rthe bottom,
then top off at the large hole if needed,
usually takes a few goes to get all the air bubbles out,
just make sure theres no air bubbles left at the seals on the resevoir,
pump the piston slowly, let it sit and repeat till no more air bubbles come to the top of the big hole,
