Hi Dwarfy,
Im not really sure what you would call it, maybe a bitsa!!! Bits of this, bits of that!!
I got a job lot of spares from a guy off ebay, thats where the engine came from. I think its a CY 29cc with a chrome dress up kit, not even had it running yet!!
The rest came from ebay as a 4wd set up to convert a 2wd, but on further inspection after i got it, it needed a new chassis as the one that came with it was bent and cracked. The front diff housings were fooked, all the plastic locating points were broken off and the rear diff (which was alloy!) was completly worn out, the needle bearings, bronze bushings, bearing collars and all the teeth on the gears were all knackered.
I managed to get a second hand replacement chassis from ebay, the front diff housings came from ebay germany and a used alloy diff housing from ebay too.
The wife and i built this lot up on saturday...YES, i did say the wife!!!! She actually built the rear diff on her own (with a little supervision!).
Still have quite a few parts needed to finish, so if anyone has any of the following, send me a PM.
Layshaft brake disc no.06044/01
Alloy servo tray
Steering servo
Hydro brake servo
Set of shocks
Body shell
Also need a set of steel gears and some advice of what ratio to go for!!
Chris
