HawaiianRevo
Active Member
- Thread starter
- #21
No, that is the default to not screw up servos. If you are running a real good digital servo you can get faster response by going to the 5 setting. If you are concerned about which servos to use on what setting email Spektrum and they will respond with an answer. Or you can call them.
Click here for Spektrum Contact Info
Contacted Spectrum today, according to them it will not hurt the digital syncro to run it at a slower rate but it may not perform at it's peak capability. They did not have an answer for why the set up screen says you have to operate the digitals at 5.5ms.
