Another question concering high idling!
waqr
Sweden
Hi!
Now I have solved the problem with my servo but now I have another question. The thing is that the idling is perfect when I start her up but when I run her and stop it takes some time for the idle to go down. Usually it takes a couple of seconds for it to go down and after it have gone down it is a bit unstable (going up and down). Why is it like this? I have been running approximately 6 gallons of fuel through the engine maybe I should say :)
You could have an air leak around the carb with one of the gaskets or you might need a new carb. You can always start by setting the carb back to factory settings and then retune it. How old is the engine and carb. If the carb is old it might need a rebuild but it is easier to buy new one from DDM, great selection and prices.
