Anti roll bar
anything from 4mm to 6mm. You know it's spring steel don't you?
Mike is right its not just mild steel rods bent to shape though it may work in the first corner then its just a hindrance.
you could make them with your rod and heat treat them but they will never be as good as the spring steels ones....
