kryptonite5b
im using the money that i was going to go to diggers dungeon with to build a new rig.. it wont be for a while,(a few weeks) but its all mapped out. im done with the other 2 rigs and completly satified with their performance so im on to the next. what makes this fun is im on a budget. its much harder this way. this is also going to be strictly street. maybe some light grass but no dirt!! becouse im on a budget, i need to make a "wow" factor somewhere. so yes it will be pink.
-for the chassis i'll be using this(mt5 v2 roller)
http://www.rampagehopups.com/product.sc?categoryId=2&productId=389
-motor will be this with the included jetpro. wanted diffrent pipe then the ddm i have for the tt
http://www.oneillbrothers.com/rccar/itemdescription/29cchkpackage.htm
for the stearing i will be using 2 of these. not the best, but think budget.
http://www.largescalerc.com/index.asp?PageAction=VIEWPROD&ProdID=860
and throttle
http://www.largescalerc.com/index.asp?PageAction=VIEWPROD&ProdID=904
and for my faverite part, i'll be using these tires/rims w/adaptors
http://www.suhracing.com/Scripts/prodView.asp?idproduct=19
5b adaptors
http://www.suhracing.com/scripts/prodView.asp?idproduct=21
was thinking white 5b rims and tarmac, but i like brp's better.
now for the wow.. i will be dropping the suspension very low. complty slammed. also the stock mt shell will be resting on the shock towers with the rear rollcage poking out the back. im going to try to run the highest gears i can. not concerned with low end torque, just want it to blister. so i'll try the 33/27's but will try the stock 35/25 set-up too. now for the pink. the stock mt shell will be a white fading into bubble gum pink(my company colors)for other components im going to use krylon plastic paint(pink). it doesn't chip or peel and is very durable if used properly(im a painter, ive used it before). i'll be doing the suspension arms,diffs, radio box,roll cage and a few other parts, but not the hubs and obvious friction parts. to protect it from rocks i have mocked up front and rear suspension arm skid plates using thin lexan, heat gun and a sheetmetal brake for perfect bends. also a side chassis deflector.. they will also be sprayed with the pink and shimmed so they arent resting on the plastic.. and thats it. my budget build wich i will start at the end of the month. the end resoult will be pretty flashy and diffrent for sure. its also less then $1400.00. i know this thread is a little early(and long) but im interested in your opinions and other crazy ideas
and throttle
5b adaptors
