the GP290's (cy 36mm topends) are around 17.5:1 compression in stock form. HIGH Compression. probably the highest compression out of the motors we can typically use for our addictions.
you ll find a few of the builders like ESP modifies some heads to accept the 2mm stroker crank and still use only one .020, stock thickness head gaskets. the ESP 27.2 and the ESP 30.5 topends are milled out for a stroker motor and stock cylinder gasket, so no stacking up to .060 in gaskets to get clearance, no oblongating the coil mount holes to drop the coil low enough to get proper clearance ect....
plus on the ESP 30.5's (and the other stroker modded topend he produces) the compression ratio gets dropped from the 17.5:1 to a 14.5:1, and the squish band is lightly modified for a better burn.
after 12 plus gallons, i just had to rebuild my ESP 27.2 yesterday. new ring, new TFE Ceramic crank bearings, new oil seals and gaskets all around. if the rain stops today, its getting installed and ran in, if it doesn't stop raining, its getting installed and ran in tomorrow at Turtles track.
