any tips on setting up fg cable brakes???
Garethw1986
Chester cheshire
fitted a used set of cables on my on road but having trouble getting them to work:lol: my servo is moving the cables fine and ive tightened the brake pads up as much as i can before thay lock up the disks, please help, also will i need bigger front wheel squares? don't seem that much room for my wheels:lol: thanks
I had problems with my MT.
On road is no problem - mine locks up every time.
Tighten up the pads until there's JUST full free movement.
Check the 'zero' position is set well, then set the rod to just not bind the brakes.
You'll need a strong servo - I recomment a Savox 1256TG.
