well, from everything i personally read posted by him specifically on this new cy 4bolt motor, about all the testing and help he was doing with/for cy on this new 4bolt, i would of atleast thought ANY of the motor info he gave would have been correct, but it was all wrong. he said it would be a 35mm bore, its a 34, he said it would have a 2mm crank, it is stock, he also said it would NOT WORK with the zen 4bolt, guess what, it works just fine.
maybe there is a communication gap somewhere, but so far, i have yet to really read any posts that would entice me sending any money in that direction.
the cy 4 bolt so far seems to be ok. not really been out long enough to get any real world feed back... and with the zen 4 bolts only costing 10ish more, and often near the same price, most folks, especially your builders, just have no reason to use them.
for info clarity, the new CY 4 bolt is a CY270. it is not a 27.2cc motor. it is a 4 bolt topend, 26cc motor (34mm bore x 28mm stroke = 25.5cc ie, 26cc) same as the Zen G270. it is a 34mm bore with a 28mm stroke, which is a 26cc. a 27.2cc requires a 2mm stroker crank. and to date, CY is the only company to offer a 2mm stroker in a factory production motor. they do it with the 35mm bore topends, yielding the 27cc and 29cc cy 2 bolt motors (note: Again not the 27.2 or the 28.5 motor. 35mm bore with 28mm stock stroke crank is a 26.9cc ie 26cc, the same topend on a 2mm stroker is a 28.7cc ie 29cc motor).
these cylinders also get used for the shinney pop top motors. those ones with the big leaky billet cooling heads on them the cy manufactures. the ones that make Purdy paperweights.
not trying to be anal, but im anal about correct info. and yes sometimes im wro, wroo, wr..
wrong (whew, got it out) but that is typically on new items, and i ll typically apply a disclaimer like... From all that i have Read, or From my best guess ect......
anyways, im sure we ll get some real world info the longer the motor is out.
