Asguard body mounts
Clubin
Build Thread Contributor
Manitoba
Here is what I did to fit my Asguard body. I originally bought it for my MCD, but it will fir fine on my Redcat so here it goes. I has to open up the wheel wells a bit so the wheels would clear, other than that, one set of MCD body mounts.
I like that Asgard body. Nice work on the mounts. What color are you painting her? And is that a Baja filter?
Yes that is a Baja air filter, nothing but the best.
As for the paint, you will have to wait, you will not be dissapointed.
Neverhappy said:
How much do those bodies cost? Are you going to airbrush that one? Looking good so far.
I can't say how much I payed for it, they are worth aobut 120.00 us or so.
I am going to airbrush it forsure, I have a plan. It is going to be real cool.
I got an air compressor for Christmas that will handle a airbrush then picked up a Iwata Revolution airbrush a few weeks ago. Haven't had a chance to get the paint yet But soon. I'm going to be using createx paints. I have a great layout scheme for mine which I don't have as of yet. Don't know how it will turnout for my first time but we'll see.
Can't wait to see what you do with the body scheme Clayton.
I have the same airbrush.
so do I:eek:
Rob do you have pics of your ascard body set up?
Clubin it's looking good.... is the body thick like fg bodies? I've been thinking out getting one cos I know my redcat one is not going to last long...i got a clear one to paint also but that won't last long either I'm sure.
Got the heat gun to the one I melted last weekend...bit of body shaping...it worked out ok.
mooman007uk said:
so do I:eek:
THis body is manufactured by ATOMIC it is a thin compared to the FG body, I think it should last, time will tell.
What kind of paint do you use??
Well if two of you use the same airbrush then I must of brought the right one. A guy I know said I should of gotten a cheaper one and used tht then use the Iwata to see how great a airbrush it is.
Faskolor is all I use and have ever used, once I am done painting I seal with Faskoat, it is like a rubberized fuel safe coating.
I never buy cheap, when you buy cheap, you get cheap.
http://www.parmapse.com/fas1.html
