Bad/good oil
Maxima Castor 927
Castor 927
Racing 2-Cycle Oil, Pre-Mix Only
Castor 927 is a unique blend of highly refined castor oil, a specially prepared synthetic and an additive system that reduces carbon and gum formation and provides excellent rust & corrosion protection. Castor 927 also contains an exclusive additive that keeps power valves cleaner and working properly. For all of us that wish to keep our air and water cleaner, Castor 927 is biodegradable. Castor 927 keeps on lubricating; where other lubricants turn to carbon or vaporize, and provides extra protection on cylinder walls, bearing journals and other critical areas at temperatures much higher than other lubricants.
Usage
Castor 927 is ideally suited as a premix for both leaded and unleaded fuels.
Recommended Premix Ratios
50-80cc (24-32:1) 125cc (24-40:1)
250cc (24-40:1) 500cc and up (32-60:1)
Technical Data
Color D 1500 Yellow
Gravity °A.P.I. 17.6
Viscosity SUS @ 100°F 617
Viscosity SUS @ 210°F 73
Viscosity cSt @ 40°C 133.1
Viscosity cSt @ 100°C 13.79
Pour Point, °F -5
Flash Point, °F 420
Fire Point, °F 480
Viscosity Index 99
SAE Viscosity 40
