As I am new to Baja and tried to tune my Baja 5B 29cc (With tuned pipe) to stock settings but I ended up messing it.
When I first adjusted the low and high needles to stock settings I noticed good improvement in acceleration and torque pickup when full throttle but then I tried to set the idle screw and then everything went wrong.
Now when I goes full throttle instead of picking up speed my Baja 5B makes a weird bogging sound and picks speed after a pause and if I give little throttle it shuts down the engine. Rotating the idle screw wont make a change in sound at all now as it did before.
I think I am too richer on Low needle and need to adjust it and so as the High needle accordingly but the thing is that I don't know how to adjust the Idle screw needle and what are the required settings. When I search for tuning tips I get all the info on L and H settings but no one talks about the big idle screw settings.
Please tell me what this screw is for?
What are the perfect settings for Idle screw?
Please help. I don't want my engine to seize.
Thanks!
Thanks!
