Baja air filter on xt. Need help please
And now that I flipped the linkage. When I turn my remote off and the car stays on (let's say I lose connection) the built in fail safe applies the brakes which is really the gas cuz I swapped linkages
failsafe just needs to be reset.
well you don't need one to make it work. I run my linkage like Heyns Racing shows in his pic. then just reset your failsafe and you will be good to go.
its really pretty simple. failsafe is easy to reset, and you already had your linkage switched around. What do you need help with?
to reset failsafe
1. Turn on both RX and TX
2. Hold the throttle (CH2) in the position you want it to be in when fail-safe kicks in (example: brake position).
3. Press the fail-safe button (little button next to the led on the reciever) until it blinks and turns solid again.
4. Test it! Go full throttle and turn the radio off. It should go to brake position.
I just ordered the shread head incline thing. My front left wheel locks up at times because the inner wheel hub where the axel connects to rubs on a long screw bc when I bought the car the dealer needed the screw for something and jimmy rigged it for me. It's directly under the hub. I'll try and snap a pic
