Rory
Well my baja doesn't run properly out of the box. Took it for a proper run tonight for first time, and somehow the power isnt getting put down and somethings slipping..
It will drive along on low throttle and pick up a little speed , but as soon as I try to use 1/2 throttle or more it just revs and goes nowhere.
I took the clutch bell off to have a look, and the clutch shoes look fine. I couldnt seem to move them out though, are they very stiff to move? Its an 8000rpm clutch spring allegedly. The inside of the bell was ok as well.
So Im thinking its something else, in the diff or something? With the left hand wheel held still, and the right hand wheel free to turn, when turning the brake shaft its fine, the right hand wheel turns easily. Nice and normal Id think. But ...
vice versa, trying to turn the other wheel in the air with the other held, again via brake shaft, it turns sometimes a little way then locks solid, I cant turn it.
