hamster huey
I was thinking about the Rampages 4 gears it uses to move. Maybe if it had a Baja style spur it would be able to engage the gears a little softer while still accelerating aggressively and also help with jump landings. On a baja once the clutch engages at X,XXXpm it then goes through a two piece spur with soft rubber inbetween the two pieces, then the power is transferred to the rest of the drivetrain. That would be of great benefit to anyone upgrading to more power. The baja drivetrain is still all directly connected but it has rubber damper also which can give a little bit for protection. I wish my baja had one to save a little on the wear and tear.
