drbelleville
- houston texas
sorry about the mispelling.
Just an FYI. After a couple tanks the boots rip. POS's. Other than that, these things work awesome. I'll have to see if the FG boots will fit.
I have the Carson CRT but with an FG diff fitted (Carson one exploded) so i'm guessing http://www.rc-car-online-shop.de/cgi-bin/cosmoshop/lshop.cgi?action=showdetail&artnum=carson_306007&wkid=27775&ls=e&nocache=1188063607-15388
would not fit, I know the Carson out drives don't fit as i had to replace with FG ones so I guess I would need to go for an FG set can anyone confirm. I'm having real problems replacing the dogbones as they are 107mm in length so far the only place that have these is Tower.
Thanks
the CV boots are really cheap to buy Part # is 443906102G its from Audi/VW dealership...... grommet part........ or try Audi part # 967340
Thanks hellya, guess I can run to the dealer at lunch time and pick some up! Are these a little less prone to tearing?
Hey CSP, FYI the Ball-drives are more efficient and less prone to tearing the shallower the angle of your arms are. if you run your arms at max ride height level your boots will tear easier. I know it sucks, but that is one way I have found the stock boots to last the longest by running at a lower ride height. Also I dremel'd a little more off the arms in the hub area of the arm so debris will not get caught between the arms and the boots and cause tearing.
Hope this helps a little
