Bearing Question. need help please.
iwik76
Uk
Hi,
I own the maverick blackout AKA rampage V3. now i am on the case with getting some performance bearings here in the uk and i want some advice about the 2 x 22*10*7mm Part # 50068 for the rampage. the supplier i'm dealing with has got all of them apart from these 2 problem ones. now upon looking on Vancouverhobbies i see they supply these two but have dropped it from 7mm to 6mm.. it's a easier size for the supplier to fnd them with the 6mm. with this drop by a mm will this be ok to run? will it have any problems?? i'm running the rampage Alu gear/dif plate will the 6mm be ok??
Thanks for any advice in advance.
It'll be fine. They offered a complete bearing set for the Rampage and that same bearing was provided. They include a shim to make up for the difference.
22 x 10 x 7's are almost impossible to find which is why we are not using them in our tranny. We moved back to 22 x 10 x 6's so that you guys don't have such a hard time finding replacements. FG has been using the 6mm's for years in their gearplates without a problem.
Leg-ends i thank you all for your knowledge.... so hopefully nxt week i'll have my new performance bearing kit... yippee..!! i'll post up the info after i get my kit (selfish i know..!!) they ship internationally...
