bearing question
oh, thank you to the OP for asking about this. much obliged. :)
are y'all topping these diff housings off w/gear oil? thin weight gear oil should be sufficient & give least resistance. or heck, lucas oil additive should work too. i have someof that.
Inside the diff out back I used 30k oil and threw front one I used 100wt shock oil they both spin smooth, the front more so but I haven't ran it yet so I don't know how it runs like this but it does feel nice
I had diff fluid and ended up putting 5k in the front and 10k in the back. I also did the shocks with 40 all the way around. It handles better than it did and I'm happy with it as a starting point. It doesn't kick out in the loose dirt as much and turns better too.
I also put 40wt in the shocks seems better than stock and what the hell did they use for the stock fluid in the diffs, geez
That's some nasty poop in there isn't it! I find naptha to do wonders. Pull the diffs apart and shake em around in naptha. It takes all the grease off nicely. If naptha gets oily change it out or it don't clean the gears. Helps getting that crap outta there
