bearing
jimbob46
Junior Member
Well i think my crank bearing went when i pull it over it makes a sqeaking sound so what bearing do i need ? And do them zero drag seal work good? thanks jim
Hmmm...i'm thinkin you have dirt inside your pull start/fly wheel, or maybe the coil moved a bit and is touching the fly wheel. I would start by removing the pull start and have a good look at it first . What kind of conditions are you running in?
I agreey with yoloda .mine did the same thing and it the coil cameloose.or the cluth housing bolts work loose.
YA I was driving in some soft grass at the school i will check that out thanks guys jim
I tore it all apart and I saw that lower rod bearing has lots play i know it should move side to side put it wyoobles real bad so i yhink i need a new crank shaft so i think i will up grade to zen which one should i get it will be going in a ramp mt i want lots of low and torque and some top end thanks jim
