bearings/hubs
HBD8T
Tx
Hello, I just ordered a rampage xb and i have read about axla bearing issues . could you use the MT Carriers,Axles,Axle shafts,sterring knuckles and convert over to a 12mm shaft to use the HPI hubs also would be a larger bearing.
Thanks
Dave
You would also have to use the MT upper and lower suspension arms to mount it all to.
It is much better to go with the 7075 RC products. They utilize larger bearings. Since the are machined out of 7075 aluminum, they are very strong also. I have never heard of any breaking.
RCDAD said:
You would also have to use the MT upper and lower suspension arms to mount it all to. It is much better to go with the 7075 RC products. They utilize larger bearings. Since the are machined out of 7075 aluminum, they are very strong also. I have never heard of any breaking.
Thanks..... I have sent the guy at 7075rc 2 emails and no reply . i sent an email to redcat for the measurment width on the frt and rear carriers to measure up to a buddies XB the frt on the xb is 22mm and the rear is 39-40mm wide would you have the measurments?
Dave
HBD8TRCR said:
Thanks..... I have sent the guy at 7075rc 2 emails and no reply . i sent an email to redcat for the measurment width on the frt and rear carriers to measure up to a buddies XB the frt on the xb is 22mm and the rear is 39-40mm wide would you have the measurments? Dave
The web site I use is hit or miss with E-mails, long story. PM me from this site and I will answer all your questions.
Well its done........ awsome....... MT axles,hubs, a arms, large bearings, HPI hubs, looks beefy and is ! :D
Deluge said:
Awesome. Should make the XB a lot more durable.
yea the diff plate shattered so i replaced that with the MT plate , nice , beefy what it needs
Here's some pics of the XB with the HD parts
/monthly_2012_05/583c6063dfbb5_100_2127(600x450).jpg.790eaac2a98342b25d0352ab76262a5d.jpg
/monthly_2012_05/583c6063e1208_100_2126(600x450).jpg.0852617bfa530d24fb7d9962456b797b.jpg
/monthly_2012_05/583c6063e2a26_100_2125(600x450).jpg.60ef3b0c7bd7454db520e6165aef29e0.jpg
/monthly_2012_05/583c6063e4247_100_2124(600x450).jpg.a7885fed583bc6b5807e91e1c2712331.jpg
Can you post a pic with the body on?
It looks like the body should still fit with some trimming.
I will post it up later. Should still fit no problem I think. My hpi adapters should be in today. I just took a v1 dominator and flipped it upside down. Gonna also try to see if I can make a gbe enabled mount up to it.
