Bearings?
waqr
Sweden
Hi!
I`m trying to upgrade my bearings on my Redcat Monster to rubber sealed ones. I have however trouble finding the dimension 10X22X7 as rubber sealed. It is the bearing at the brake hex that have this dimension. What happens if I use 10X22X6 instead? Is this possible?
you could check with boca bearing , I think you will find besides the spacing, you would have to shim the smaller bearing, the bearings will be the same 6 or 7 mm wide.check the specs on the boca site.
