Bearings
I have a limited amount of the kits on-hand.
There is still one issue I haven't been able to sort out yet.
The kits do not contain one bearing. This is the bearing that goes on the brake shaft. Its an odd size in width and needs to be custom made from the factory I work with. I have been trying to find a factory that has them as shelf stock but its on the back burner at the moment.
I will be willing to sell kits at this time without that bearing if you guys want them. They will come packaged in my Signature nearing box same as the Baja and FG Kits but will not have a fancy label.
Ill release pricing later on this evening.
Rob,
The bearing kit from FastEddy is needed because the stock bearings are not good?
Also any news on the brake shaft bearing?
BRC
No, the stock bearings are good, but FastEddy's are muich better.
I haven't found the brake shaft bearing. I have to look at some of the UK distributors.
