bec problem
auto2
i hooked up a castle bec to my xb-e and its not working. i disconnected the red wire from the esc plug .is that correct with the hobbywing esc? fan turns on but servo doesn't work or motor.
I just woke up and am trying to visualize all this for ya. If you are running a seperate BEC to power the RX/servos all I think you need is the signal wire off the ESC to plug into the RX.
yup so lets assume the CC bec is NG :-( i wanted to see how the servo worked with more juice. ill hook up the bec to my laptop and see if its alive.
